I have always built my own shuttle machines and been very happy with them. Maybe not the cheapest or best performance but very easy to build and I know it will all just work. No need to worry about cooling, PSU, motherboard etc.
Sadly my last Shuttle died (well it could just be the HD but this gives me an excuse to upgrade).
I have already specced a shuttle system and one using a silverstone case and an ASROCK motherboard. I am also looking at the lenovo H520s, alienware x51and gateway SX2870
8GB RAM
2TB HDD
i5/i7 or maybe trinity A10
With that in mind:
1. What will you be doing with this PC? Gaming, Photoshop (or other intensive programs), Overclocking, Web browsing, strictly HTPC/Playback, etc. (If you have multiple things you want to do with the system, make sure you rank them from most important to least important).
Web browsing/hulu/netflix, Photoshop, some home video editing, I can dream that I will have time to play games one day..
2. What's your budget? Are tax and shipping included in this budget? Is your budget flexible? Is cost a driving factor in component selection?
$700-$800.
3. Where do you live? Do you have any big B&M (brick and mortar) computer chains nearby (e.g. Microcenter, Fry's, etc)?
Near Frys, Bestbuy et al
4. What exact parts do you need for that budget? CPU, RAM, case, etc. The word "Everything" is not a valid answer. Please list out all the parts you'll need.
Motherboard, case, CPU, Fan, PSU, Memory, DVD
5. If reusing any parts, what parts will you be reusing? Please be especially specific about the power supply. For reused parts, list brands, model #s, and, if applicable, firmware revisions.
May reuse my PNY 8800 graphics card (it fit in my old shuttle case) - depending on if it's better than whatever come on die
6. What specific features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? etc. Which is more important, size of the system or having the particular feature? Make sure you indicate *required* vs. *wanted* for each feature you list.
HDMI, USB3,
7. What resolution output do you need? 1080p, 720p, DVD quality, etc for HTPC or list Vertical/horizontal resolution for non-HTPC SFF rigs. Do you need multiple monitor output?
1920x1200 and 1080p
8. Does this system need to fit into a particular space? Think entertainment center shelves, closet space, rackmount, etc.
around 12"x8"x7" smaller the better
9. How comfortable are you with custom case design/modification and electrical wiring? What tools do you have (Screwdrivers/Leatherman, Drill, Dremel, Metal snips, Soldering Iron, Bending Brake, CNC/Welding machines/Plasma cutter, etc...)?
No modifications to the case
10. How important is the noise/silence of this sytem? HTPCs typically want to be quiet while all-out SFF gaming rigs don't care
Quieter the better
11. How mobile does this system need to be? Need a carrying handle or carrying straps? Is weight important (carry-on bag, etc)? Water cooling quick disconnects, etc?
Sometimes move the PC around to another room, no carrying handle needed though
12. Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? Is it 32bit or 64bit? Remember that OEM copies of Win7 have issues with new motherboards
I have the 32bit Windows7 Upgrade license so probably not. Could wait until windows8 comes out which maybe cheaper
13. When do you plan on building/buying the PC? Immediately, in a couple weeks, 3-5 years?
ASAP
8GB RAM
2TB HDD
With that in mind:
$700-$800.
HDMI, USB3,
1920x1200 and 1080p
Quieter the better
ASAP
