sladesurfer
- Feb 4, 2006
will the 7/16" tubing fit in the pci slot of a case? I dont want to MOD my case thats why im asking.
No it won't. BTW I am using all 7/16 tubing in my rig. If I had to do it over again, I'd use smaller tubing. It's been proven that the tubing size makes very little difference on modern water cooling hardware.
is that true?
wow, its been proven that flow doesnt, but i guess if u have higher flow/smaller tube, the same amount of water passes.
would you recomend a 3/8" loop with a laing ddc pump of some sort then?
Yep. It's been proven for a *long* time now... But apparently the Zealots only heed the wisdom of a select fewToo bad I love the look of larger tubing!
Even flow-rate isn't that important, as long as you're over 1gpm. Case in point, lowering my MCP655 from 5 to 2 makes no difference in temperatures even after 45 minutes of full load.
