Judd Sandage
- Jun 6, 2004
I have a creative X-Fi with its 4 3.5mm 7.1 channel outputs, and just picked up a set of the Creative Soundworks 7.1s from a friend, now the speakers came with a 4 to 3 cable for use with the older soundblaster cards, four 3 pole 3.5mm ends for the speakers and three connectors on the other side, 2 have 4 poles and 1 is a 3 pole, my old Logitech's had just a 3 to 3 setup, used that cable plus a spare 1 to 1 cable just lying around... what I want is something that has four 3.5mm ends on both sides... and color coded... creative made them at one point... but I never bought them and now I can't find anything on them other then this link talking about them http://support.creative.com/kb/ShowArticle.aspx?sid=53375
Any ideas on where I might be able to snag up a set?
