6970 X-Fire Problem
BeaverD
I have a problem that I'm hoping somebody can give me some insight to. I have 2 of these cards linked. I'm using an LG 37" LED TV for my display. The setup is working properly as far as I can tell but the problems start when I start a game with X-Fire enabled.
What I get is this: http://www.youtube.com/watch?v=rjeTjlIeUuI
With crossfire disabled it looks fine. I've tried it on a Visio TV and the results are the same. I try it on a monitor and X-Fire seems to work. I have a ticket open with XFX but they haven't been able to give me any real feedback that has helped.
I've verified the TV runs at 60Hz. The drivers are set at 60Hz. One of the tech suggested I run the drivers at 59Hz, but when I try to apply a 59Hz refresh rate through CCC the dropdown just jumps back to 60Hz and won't stay at 59.
I can't be the only one with this issue can I? Anybody have any ideas what's going on and/or how to fix it? I don't understand what happens to the signal going to the TV with crossfire enabled that would cause this problem.:confused:
