6970 vs 7950 3gb
moteasah
Bottom line. For single card setups, 60" 1080p. Will the 7950 be better in all ways than a 6970? Ignoring price as we don't know for sure if the 6970 will drop at all, which of the 2 is better?
How can you even ask that about an unreleased/unannounced product? Better in all ways? I'll tell you one way it won't be better - price.
I think the 6970 will reign supreme in single card setups once the dust settles, 7 series seems badass, but overkill on just one monitor IMO
Why did you put "60" 1080p? 1080p is 1080p.
Perhaps he meant 60Hz?
I'm not accusing you of this, but I'm really getting sick of people saying a single 7970 is overkill for 1080p. 1080p at 60Hz perhaps, but not 120Hz. Just because I only have 1 monitor doesn't mean I don't need 3GB (for AA) and insane speed (for 120hz fill rate). Getting all this without crossfire's quirks will be icing on the cake after I purchase mine on release day. Also, yes, it is worth it for ME to replace my 2 year old, 2 generations old, ~$700 (when purchased) video card with a $500-$600 one. Also so sick of people saying it's overpriced, then recommending someone 2 2Gb 6970s or 6950s. Basic math FTL.
People still use 2x69X0/GTX5X0 for 1080p, and it's worth it to them- why wouldn't a single 79X0 also be worth it?
I'm personally only using HD6950 2GB Crossfire for 1600p, but I'm also just trying to play BF3 MP, not max it out. I honestly think I'd need a pair of the HD7950 3GB cards to do that (which would be much cheaper, and faster, than GTX570 2.5GB or GTX580 3GB).
Yea I meant 60". Just habit to lost specs. It's 120hrz. I have no plan to use a multiple monitor setup. I in a way want overkill now in case in 2-3 years something comes along that demands higher performance, I'll be ready for it. Also adding a 2nd 7950 later on will be an option. Maybe they will drop a little when I want to add a second card.
I'm pretty set now on 1 7950. Hoping they will come out soon as I want to start playing some games I missed out on from not having a gaming PC for 2 years. Portal 2 omg.
I don't think any benchmarks have been released yet for the 7950. So it kinda is a pointless discussion till we can see something.
Just be aware that a 120Hz TV is not the same as a 120Hz monitor - the TV still only takes a 60Hz input, so you don't necessarily need a card that can do 120 fps at 1080p.
