applegrcoug
- Aug 28, 2021
I have a 6950xt that I acquired that I was hooking up and going to try it out in Minecraft. I use a 512 resource pack and then the SEUS PTGI shaders and it loves VRAM. On my 3090 it was using in the 18GB range and manages to pop out 40fps on 1440p
So anyway, I thought I'd give a 6950xt a whirl and see what I'd have to turn down. (I want to use my 3090 for an Ollama based RAG machine) I turned some settings down and got it to fit in the 16GB VRAM and was managing a whopping 18fps. But the GPU was only running at like 55-60%. From a rasterization standpoint, I was expecting a result similar to the 3090. So So I popped up the stats for all the threads on the 11700 I was using. None of them were pegged...maybe like 60% was the max.
Next thing I tried was shutting off all the textures and shaders. You know, where I should be getting like 1000fps or something stupid.......................60. I mean the 6950xt isn't breaking a sweat to get the 60, so that good I guess. I have the fps limiter on the windows display settings set at 144 and in minecraft at unlimited, so I'm not sure what is going on.
I can run like heaven or valley and make the gpu work like it is supposed to and it trades blows with the 3090 like one would expect.
I'm not as familiar with the AMD cards. Is there something in the adrenalin software I'm missing??
