6950 screw size
cj3waker
I lost one of the screws while running an aftermarket cooler on my 6950, was wondering if anyone knew the size so I could save some time in the hardware store
not the backplate screws, but the 4 gpu retention screws i.e the ones with springs...which I also need another of...
thanks
these things could vary dependent on what model you have. id sugest taking one with you and seeing which nuts fit on it, then buy the appropriate one.
and start in the metric section, just as a guess
you could probably use a split washer if you cant find a suitable spring.
