6950 HDMI Audio
xacid
Bought an 6950 card a few weeks ago. I'm using one dvi output for my main display and an hdmi output for my 40 inch LCD 2nd display which i extend my desktop onto.
Everything works fine video wise but when I boot windows or something is changing the default audio device from my VIA chipset to the ati hdmi output for no reason.
Its a fresh install of Windows 7 Ultimate using the 10.12a hotfix drivers.
Edit: If a mod can move this to the audio section that be awesome~ shoulda posted there in the first place.
Set the default audio device to the VIA. Go into the sound control panel and right click on the via. Tell it to be the default output device and the default communications device.
I've had it set as default. What's happening is somethin is switching it to the ati hdmi output after booting. The boot sound comes thru the VIA output but after everything is loaded it switches. I've even had the playback devce panel open and watched I switch. Can't find anything on google as to why it's happening.
