6950 CF question
Drazn
With the CF setup is it true that the game can just not support crossfire. Which in that case it would be just like having a single card?
yup its true and yes if crossfire isn't supported in the game/drivers then it will just use the single card. in some cases it can also hurt performance so if the performance looks like shit and its only using 1 card, then disable crossfire and it should fix the problem til AMD can add the crossfire profile or the game developers fix it.
