Hey I just bought a bunch of new parts and have a fresh install of Windows 7 running. I downloaded drivers for my new XFX 6870 HD video card and after install/reboot sequence I get this:
C:\Windows\system32\atiadlxy.dll is either not designed to run on Windows or it contains an error. Try installing the program again using the original installation media or contact your system administrator or the software vendor for support.
I then proceeded to uninstall the driver software and uninstall from my device manager. This time I downloaded the driver from XFX site after registering my video card. Once again after install/reboot sequence I get the same error. However this time I noticed(I did not notice/check on first attempt of driver install) that the install had fault(s) which turned out to be an error installing the HDMI Audio driver.
Well I have uninstalled and tried installing the catalyst control center + driver + ect.. ect...
Same error occurs.
So any suggestions as to what may be my problem would be a great help and thanks in advance.
Specs
VGA: XFX 6870 HD
CPU: AMD Phenom II X6 1075T 3.0GHZ
Mobo: ASUS M4A89TD PRO/USB3 AM3 AMD 890FX
PSU: 700 Watt
Ram: 2x4 Gig 1333 DDR3
OpSy: Windows 7 Pro. 64 Bit
Same error occurs.
Specs
VGA: XFX 6870 HD
PSU: 700 Watt
