I plan on taking the dunk, plunge, swim, dive, cannonball or however else you would like to refer to watercooling.
My system is a EVGA 680i w/ E6600 (Currently cooled by an SI-128), and an 8800GTX.
I plan on upgrading from a mid-sized ATX case to a full sized one. I've narrowed it down to the following:
http://www.newegg.com/Product/Product.asp?Item=N82E16811146029[The cases I own right now are almost all NZXT's and they are absolutely fantastic.]
http://www.newegg.com/Product/Product.asp?Item=N82E16811133143
http://www.newegg.com/Product/Product.asp?Item=N82E16811133012
http://www.newegg.com/Product/Product.asp?Item=N82E16811133154
I've never had a Thermaltake but out of the TT's I'm likely the Eureka the most. I'm really disliking how the power button is behind the ODD Shield.
Also I've been reading that the best watercooling setup is gonna be random parts from different manufacturer's. So I definately need some major advice.
Goals (#1 is the most important):
1] Need enough cooling to get my E6600 to 3.6.
A] Looking for something no more expensive than $350.
B] Would like something centered around ease of use...
C] ...and stable.
As far as A goes, I'm not a penny pincher. I do not necessarily like saving $5 by switching to a particular peice coming from a random generic company.
-Appreciate the help.
C] ...and stable.
