680i unreasonably high idle temperature
lostknight
I have two Core 2 Duo boxes. My linux media server is a 6300 with the stock fan, and it works well. Using sensors, Idle temperature is about 32 degrees (c), and load is somewhere around 44 (This is in a Antec P180 case). This is a DS3 mobo. I haven't bothered with overclocking it because the DS3's passive chipset cooler would probably be a time bomb waiting to happen.
On thee other hand I have a 6400 on a BFGtech (nVidia built) 680i board. It's pretty much identical to the eVGA 680i board. On top of that I have 2 fans up front (antec), A fan behind the board, and a new Antec Trio 550W power supply. Each has the fans running all out. On top of that I have a Zalman CNPS 9500 LED sitting on top of the CPU slot, with the special zalman thermal grease. Using Speedfan 4.2 Idle temperature in Windows is about 47 degrees, using Sandra's Processor Arithmetic to generate load, the CPU spikes to 55 degrees without any over clocking at all. Standard bios settings, with voltages set to auto. Case is a a Coolermaster Centurion, the fan on the CPU faces the front of the case.
And this is with a downrev bios. When I move to the newest BIOS, it kicks the temperatures up another 5 degrees.
Has anyone seen this on 680i before? The consensus seems to be not to let the processor stay in the 60s, and certainly keep it below 65. Any ideas? So far I am not a happy camper with the 680i, after buying nothing but nVidia for my performance machine since the nForce2 chipset.
[edit]
I just installed Core Temp .95 (had to reboot and disabled protected drivers to do it - Vista x64). It's showing tJunction at 85(c) and Core 0,1 at 37 degrees idle. Under load that goes to 84(c), 45,45 under Core Temp. Maybe it's just bad tools? I am going to research this.
says who? its mostly personal preference but anything under 80c is fine for these chips (under load) i like to keep mine in the 60s, lots of people run them in the 70s with no problems. 85c is the max its rated for and anything over 80-85c is starting to damage the chip.
dont pay attention to tjunction it never changes, core temp of 37 idle and 45 load is very good. this is on stock speed i take it? you have plenty of room to play with. also use orthos blend, prime95 or intel's TAT to load the processor. those will give you the absoloute maximum stress your CPU will ever see. just because task manager says 100% doesnt mean its using all of the power available.
edit: in regards to bios changing temps, some bios revisions can give slightly different voltages or control fan speeds differently, among other things, its generaly not something to worry about unless its a large difference
Excellent. I am still a bit worried about the 5-10% jump on the temperatures as reported in the BIOS, but have been playing with Core Temp (TAT apparently won't run on Vista x64) and Orthos and it looks pretty stable. It looks like the SpeedFan numbers were just plain wrong, leading to my sense of panic.
Thanks!
