680i Problem
Shainonex
I have a BFG680i Motherboard
I keep getting the "--" often... what seems to be the problem?
My System Spec:
Intel Core 2 Duo E6400
1 GB Crucial Ballastix Tracer
Evga 8800GTs
Antec 550W
80GB WD Sata
HP DVD Writer
Soundblaster X-fi xtrememusic sound card
often? do you mean it boots successfully sometimes, and other times you get double dashes? when mine got double dashes, it never even posted again. you can check the evga forums, its the same board, and see if there is any solution/fix to that besides rma.
I keep getting the "--" without post... when I turn on my pc it stay "--" nothing came up on my screen... I try again the same "--" appeared... I try it like 10 times still same thing... nothing showed up... =\
