I have a strange problem with a home theater PC that I am setting up. Not sure if it is a video card or mobo issue. The mobo is a evga 680i, video card a 7950 gx2. The gx2 will not work in the primary PCI Express slot. There is no video signal, though the PC does post with 1 long beep and 2 short, which I think means a video problem. This card is old so I just assumed it died. I installed a 7600GT that I know works and had no problem. Gets a video signal and boots right up with the 1 beep like normal. Then i decided to move the 7950 gx2 to the blue secondary PCI Express slot and it works in that slot perfectly, though I cant use it this way because it says I need to move the card to the primary slot.
Does this mean I have a bad PCI Express slot? And if so, why does the 7600GT work fine in that slot, but not the gx2?
