680i or 780i
After forcing a return on my PSU and after checking the new 8800GT the ugliness of the 680i chipset has reared its head: the CPU INIT error...
I am RMAing my Striker and now looking into an 780i board...
CPU init error is strictly the striker and not 680i. I've dealt with it many times and it sucks, at one point my PC was down for 2 months because I didn't want to deal with it.
My apologies for blaming all 680i chipsets.
How did you manage with the Striker's 'CPU INIT' error?
Yes the CPU INIT error is unique to the Striker howevere the reference boards give C1 errors and have other issues.
Every board based on the 680i SLI chipset is pretty much a turd compared to your average Intel chipset based board. Therefore the 680i SLI chipset is very much at the heart of the matter.
I have a BFG 680i board that i bought not long after they were launched. I've had 0 issues with the board. I've been about to push my E6600 to 3.6ghz on air fully stable with only a minimal bump in the voltage. Going to try SLI this weekend on the beast and see what happens. But so far i have 0 complaints. I would steer clear of the Striker though... just my 2 cents.
Can someone just answer a few quick questions for me...........
Do both the 680i and the 780i motherboards feature a 6-phase PWM and non solid-state electrolytic capacitors? Or is that just the 780i?
Oh, and does anyone know when the fucking "FTW" version of the 780i is going to be released? I also heard they're making a 680i version, can anyone confirm that?
Thanks,
- Joey
Thanks,
- Joey
The 680i SLI and 780i SLI reference boards use the 6-phase power design but non-reference boards do not.
I seriously doubt they will make a 680i SLI FTW Edition. There would be no point in doing so.
What about the use of non solid-state electrolytic capacitors? Found on both 680i and 780i?
Figured as much. But any idea of a release date? Month? Year? Never?
- Joey
- Joey
Yes both 680i SLI and 780i SLI reference boards use traditional capacitors. Most of the non-reference boards I've seen use all solid state capacitors and 8-phase power.
Thanks Dan.
I pulled the trigger, bit the bullet and took the plunge this morning. I returned a damaged Asus P5K Deluxe board to my local Fry's and picked up an XFX 780i board in it's place. My original plan for my new rig called for a 780i board and though I wanted to use EVGA (Fry's = Sold Out!), I don't mind using XFX.
Anyway, I examined the board and I noticed the processor power circuitry is using solid state electrolytic capacitors, or at least that's what it looks like. Not sure if it's 100%, but there are several solid state capacitors near the power circuitry. The rest of the capacitors on the board are all traditional liquid cap capacitors. Not bad by any means, they should preform and last long enough for me to update/upgrade sometime a few years down the road.
I'm generally happy with the construction of the board itself. This is the first time I've held it and examined it in person. But I've read so may reviews and posts and endless spec sheets.
Anyway, anyone got any suggestions for my board? I noticed @ XFX, I should update the BIOS to P03, and I also heard the stock thermal interface material with some Arctic Silver, is that a solid suggestion? Any other suggestions?
(BTW: I have almost every part I need for my new rig except for my video card(s) and the CPU/processor. Not sure if I'm going the E8400 45nm route or the Q6600 route. And video card depends on if I want to run SLI right now or wait and get a second card for SLI a bit later. But I am going to run SLI. Probably an 8800GT, 8800GTS, 8800GTX or the 9600GT, or maybe the 9800 series later next month.)
Thanks,
- Joey
