I'm a bit confused and hopefully you guys can help me out. I'm replacing my ultra x-connect 600w because it was in the process of dieing. I decided to go with Corsairs HX620W Modular power supply which should work great. Well I hooked it up, and I can't get my pc to power on. There is this blinking blue light that is in the top right corner above the rams slots by the capacitors that is flashing. I notice when I put my other power supply in and turn on my pc, the light is always on and not flashing.
So does this mean my power supply is defective, I'm going to be really ticked off if it is, as my pc's case sucks and it is a pain in the ass to swap out the PSU. I have to remove my motherboard to get the darn thing out.
I'm sure the 8 (left side of cpu) pin and 24 pin is seated all the way. I just plugged in my old ultra power supply into just the 24 pin connector into the 680i and it starts with only that connector. I did have to remove the board to get the old ultra psu out. That leads me to believe there isn't a short on the board. What does that blue blinking light mean?
Who thinks my new Corsair HX620w is defective?
THIS IS POSTED ON EVGA SITE AS WELL SO LETS SEE WHO CAN FIGURE THIS OUT FIRTS
