680i nb/sb chipset coolers
stain.
What is a good, and reasonably priced cooler that's compatible with the 680i north and south bridge?
is this any good?
The 680i from what remember gets pretty toasty, i'd recommend something with a fan on it.These two should a good price/performance pair.
NB: http://www.petrastechshop.com/thexspiinoco.html
SB: http://www.petrastechshop.com/evvcvgcodnf4.html
that is a good combo for nb and sb. i currently use them both on my 680i. the evercool is the one of the few aftermarket option for the MCP if you are using sli. if you are using a single card, the Thermalright HR 05 SLI IFX Chipset Cooler is not a bad choice and does a better job than the evercool once you attach a fan to it.
http://www.heatsinkfactory.com/thermalright-hr-05-sli-ifx-chipset-cooler.html
I added the thermalright kit to my Striker board... still going strong at 450FSB with the E8400...
