680i front panel connector problems
BFGuy1741
So here's the deal. I am building this amazing computer for my friend. It has high end everything in it. A QX6700, 8800GTX, and the EVGA 680i motherboard. He wants me to put it all in a TJ-09, which I must say is an amazingly beautiful case.
It is running perfectly right now except the front panel usb ports are not working, no power no nothing. I tried flashing the most recent bios, but no luck. I also tried connecting the usb connector to the other header, but still no luck.
I'm running out of ideas and I need some help. :(
If the header connectors are anything like the TJ07, make double sure you have them oriented correctly. On the TJ-07, its possible to install them upside down.
hmmm. I hadn't thought of that, but I'm pretty sure there is a hole blocked in the wire to force you to put it in the right way. nonetheless, I try and see if that's the case.
Well if the Tj-09 has the 10-1 connector (blocked hole) you are golden, but the TJ-07 simply has 2 x 4pin connectors per bank. It wouldnt be too hard to install those ones incorrectly.
