680i BSOD and error code 75
Jcdenton69
my 680i has been working flawlessly on an overclocked E6420 for about a year, until today. it locked up when i was playing some WoW and i thought nothing of it and rebooted. well, later in the day it gave me a BSOD, it flashed up on the screen for less than a second, i couldnt read anything and then the computer rebooted its self, during post it hangs there for about a minute with the error code "75" displayed on the motherboard. having lost my 680i manual, and doing a quick google search i came up with nothing. what is the fix for this? ive already run memtest for 2 hours without errors, reset my CMOS, and that hasnt seemed to work. the computer will boot up fine, work for 3 - 5 mins then give me the BSOD and reboot.
ack.
Another 680i bites the dust. :mad:
First question : what make of motherboard ?
Second question : What does the bluescreen say exactly ?
EVGA 680i, and no idea what the blue screen says, it comes up on screen for a fraction of a second, and then reboots its self, theres hardly time to read 1 word on the screen before its restarting its self.
Manual's are generally always available online:
http://www.evga.com/products/pdf/680i manual.pdf
LED codes start on page 117. Code 75 says Detect HDD - IDE device detection.
Not really sure what it means considering you are already in the OS. Could be hard drive failure? You should probably contact EVGA.
Edit: Run some S.M.A.R.T tests if your drive supports it, and check the event viewer to see if the BSOD got saved (if you can get in long enough).
Flash to P31 BIOS if you haven't already (get it from the EVGA forums) and do a full reset of the CMOS -- move the reset jumper, unplug the PSU, pull the battery, wait 15 minutes, put battery back in, move jumper back, try again. Remember to set your RAM to proper voltage after the reset. If you're running with 4 sticks of RAM boot with just one, set voltage, then shut down, install the other three, and try again. You might try with just 2 sticks for the sake of stability, too. If it keeps blue-screening after that RMA the board.
Without really knowing what kind of Voltages, or other Mods you've done, it's hard to say.
One thing that comes to mind is the Darn lousy TIM (Thermal Interface Material) that was used on all 680i Mainboards.
I'm running the same setup, but Replaced everything with AS5 on CPU, MCP, CPP, on the Voltage PWM Caps I used AS Ceramique, and haven't had any Problems.
Yep....latest bios is a must with 680i.
Yep....Thermal solution needs to be improved.
Do both if ya can , reset cmos and start again.
It's quite possible it's simply a bios issue......the track record for 680i bios' is about the same as the chipset in general (spotty at best)
