680i board is dead? Please help...
lordsegan
I have tried two 2x2gb kits (OCZ and Super Talent).
With both, the system often hard locks when booting, even at stock settings. What happens is as follows:
I hit the power button:
25% of the time, I get long beeps and no video.
25% of the time, I get corrupted looking BIOS-POST screen
25% of the time, I starts to boot, then it hangs while booting
25% of the time, it boots OK and then is fairly stable
Help?
Ram is at default voltages. I have a 2x 8800GT and a Corsair 620W power supply.
Your 680i board should have two LED read outs within the bottom-right quadrant of the board. Please review what code these readouts display under the various circumstances you described above.
Two long beeps and a readout of C1 is an all-to-common occurrence on 680i boards. It either refers to bad RAM or a bad memory controller. Check to see if its the former by testing your RAM in another computer, and by testing other RAM in your motherboard. If the RAM doesn't work in the other computer, but different RAM works in your motherboard, you can assume that one of your original sticks of RAM is bad and needs to be replaced. In other cases, the motherboard's memory controller may very well be the culprit, especially if other RAM doesn't boot up in your computer, or if the original RAM you had in your PC had been working for a while (and given the history of 680i north-bridge failures, this would seem to be the more likely scenario.) If it's the memory controller, then RMA the board.
Again, 680i boards fail far more often than their competition. Google Dead 680i or 680i C1 for more information.
