680i, and my keyboard.
stain.
When I use my keyboard for things, such as gaming, or typing (it's a compaq keyboard I've had for years, but I keep it because I like it a lot), it'll beep both in game, and in non-game apps, like a key's been held down too long. Problem is, It happens when I'm typing regularly. I can understand the game, but it's never happened before. Is there a setting on either my mobo, or windows to fix that? It's kinda irritating.. hear a beep, then my character in game moves left untill I hit a again.. grrf.
PS/2?
It's an issue. You can either get an RMA, or you can get a USB keyboard.
Personally, it hasn't happened to me, but I hear of it happening often with the early EVGA 680i Rev. A1 boards.
Sounds like the old repeat function and it did used to be in bios, think it's called 'repeat'. Not sure about 680i.
Windows has a feature where you can enable certain keystrokes to perform a certain function or act as a shortcut/hotkey. I believe that it is possible to activate this feature by pressing or holding down a certain key/key combination. It may be possible that you have inadvertantly enabled this feature, and so when you press certain key combinations, Windows may interpret that as an instruction to perform some action that may not be possible at the time (which is the usual cause of a beep error).
Unfortunately, I cannot recall what this feature is called (sticky keys, maybe?) or where you can find a menu to determine whether it is enabled/disabled. I'm sorry I cannot be more helpful, but this is the only thing I can think of. Those who've posted above me are probably more on target.
I just picked up this board last umm.. monday, so a week ago. it's rev. AR unfortunately. Is it in BIOS, or in windows, the repeat function?
