680i 8800gt sli
TxRydawg
Is there anyone in the Dallas area that might have an SLI connector for this motherboard? I have tore my house apart looking for it after I scored a 2nd video card and I have no way to connect them for SLI. I'll meet you and give you a couple of bucks if you have one. I don't think Fry's sells them seperately...thanks in advance...=)
You can order one online for ~$7. I have a spare I could send you if you get desperate, but I'd want a couple bucks and actual cost of shipping.
Are all SLI connectors the same, meaning, does it matter who the manufacturer is? For example would an EVGA sli connector be same as an Asus?
Not exactly. Some boards have different spacing between the slots, so if one board comes with a non-flexible SLI bridge, you won't be able to use it on another board with a different amount of space between the two PCI-E slots. Make sure you either get a long enough flexible bridge, or if you get a rigid one, that it comes from a board with the same slot spacing as yours.
Almost all boards use the same slot spacing though... All I've seen at very least, since the 680i/780i/790i boards all support Tri-SLI and that connector is non-flexible.
Most do use the same spacing, but I'm just pointing out that it isn't the best idea to take that for granted in case you do end up with a connector that doesn't fit.
The local Fry's here in Dallas didn't have any for "sale" but being the geek that I am, I knew of one place that would have them....So I asked the guy that does PC repair at Frys if he had any lying around and sure enough he did! Big ups to the guys at the Irving Fry's. I really appreciate it! Now I have 8800GT's in SLI...woot!:D:D:D
