6800U power connection question
LordBritish
The 6800 Ultra has 2 molex power connectors - one primary, the other secondary.
I have a dedicated power line going to the primary connection, but the secondary connection is sharing the line with 3 80mm case fans.
I doubt that 3 80mm fans is drawing too much power away from the 6800U.
Your thoughts?
what PSU do you have? I wouldn't be too concerned if your PSU is good quality
Richard Garriot
Using 460W Enermax - +12v is 33A
I think it's ok, just checkin.
You know my real name :D
