6800GT Flash Problem...
HighwayAssassins
Hey I have flashed my GT before and i use the guide found on this forum and it works very well. I tried again this morning, and, yep i fucked it up! The card is fine however, its when the drivers kick in when windows starts the computer freezes. When i load safemode it boots fine and the card works great, and when i uninstall the drivers in safemode i can boot XP normally. I want to flash back to another bios, which i know will work, my problem is you can't flash unless you have the nVidia drivers running...anyone know how to get around this?
you should be able to do it through dos prompt, you have to make a start up a disk and put all your bioses, and nvflash on the same disk
will it work on the disk even though it wouldnt in safemode?
Ok i got nvflash 5.06 for dos and i am trying to flash it, and it always tells me GPU Missmatch...anyone know how to make it work?
