6800GT and not running BF2
Todd156
Well im pissed, i bought a brand new $280 video card off newegg to play BF2 and i still have the same friggin problem. Start the game up, goes to a black screen for a little, then i go right back to my desktop, i do not know what to do. Anyone care to save me? My systems in my Sig.
i had that problem with a diffrent game when I channeged my monitor did u hook up a new monitor?
do you have any apps running that force a refresh rate? Try disabling them.
I've heard this problem before. Have you checked the EA boards?
This happened to me if I was running FAH in my tray, if you are running it try closing it. Worked for me.
ditto. if you have anything running in the tray taht is going to take priority over the game, close it.
I had the same problem, go to the My Documents folder and delete the Battlefield 2 folder in there. This holds your settings and profile for the game. Start up the game again and it should work now, but you'll have to set your settings again.
Shadow27
Shadow27
This fixed my problem of playing for a while and then just crashing to the desktop out of nowhere.
Generally this is a refresh rate problem. If none of the other suggestions work, try this:
Do a complete wipe and reinstall of your driver pack. Install BF2 again and select a video res and refresh option in-game (ie 800x600x32 @ 100hz). Close BF2 and run refresh rate fix/program such as reforce.
This actually didnt work for me, but I run an ATi 9800 pro. My roommate did the same process and it works fine, he runs 2 6800GTs in SLI.. so you might have better luck since you're running nVidia.
um no dont reinstall. Just change the resolution/refresh rate in your .con file to something your monitor can support
I had that problem..I know this sounds stupid but make sure you have updated drivers. That was my problem. If that doesnt work download the drivers teh BF2 has.
yea ive got all new drivers and such, im just playin around with the refresh rates and res's now.....
anyone think it could be my monitor?....i do have a 15in LCD, brand is Kogi.
Not bloody likely.
If it was your monitor it wouldn't crash back to desktop; it would just stay black, because your video card would think everything was fine. I'd say that there's nothing physically wrong with your monitor. Now, if there's something in the refresh or resolution settings that it doesn't like, your computer will know. However, it seems unlikely that this would cause a game crash, either.
yea its not the monitor, i just tried my 17in envision and i still get the same crap, ive tried all different resoloutions and refresh rates, nothing. Anything think its my cpu? EaGames says that 1.7 is the min, but that shouldnt matter when trying to get the thing friggin started up...right?
What's your cpu? While you're at it, what are the rest of your system specs?
Is your DirectX up to date?
My Sony Monitor does that for only 3 seconds and then it loads ... does yours do the same or no?
I hoping I can get a new monitor soon, I've found a nice 1600x1200 Widescreen Samsung.
Yeah, its normal for the screen to be black for a few moments while the splash loads.
Todd, those are some strange specs..lol. I don't think they're the problem, though. Have you searched the EA boards yet?
This is the first game that its happened with, all my other games are fine.....HL2, Brothers in Arms, Far Cry, Counter Strike, GTA SA...... They all work fine. And can anyone point me to the EA boards? Ive looked at the eagames support page, and according to that, its my video card or its drviers, which are all updated..
I the thoroughbread 1800 a 400MHz FSB? I don't think so, but your memory is. Maybe there is some kind of conflict with the memory running at a lower timing?
What card did you upgrade from?
If all your other games are running okay i would image it is a driver issue. Try drivercleaner (following the directions in the sticky) http://www.hardforum.com/showthread.php?t=752253 and then re-install them. If that doesn't work, i would move on to an uninstall-reinstall of the game itself. Unfortunately, that proc is really going to limit the benefits of your new vid card, but that's a whole separate issue.
The other day I noticed my desktop shortcut to BF2 was bringing up a black screen and punting me back to windows.
Then I tried running the game through the auto-run when I insert the CD.... and no problems.
Just a thought.
I dun know if this will work or not. But, try running it in window mode. To do this:
Change: BF2.exe" +menu 1 +fullscreen 1
To: BF2.exe" +menu 1 +fullscreen 0
Oh, that's in the propeties of the shortcut.
I had this exact problem with a reload of FarCry on a new HDD. Turned out I had forgotten to update directx.
:cool:
That sounds like the same problem as HL2 and 77.xx drivers. Hopefully its just a driver issue. But then what, have to change drivers for each game? That would suck.
yea i think it has to be drivers, my old card was a geforce4 ti4200, guy treated me well until this, i thought it was the card that wasnt running it, but i now ive found its something else....
