6800GS SLI or What?
Hawk
As seen in my sig I currently have a 6800GS and I want to upgrade to better video card but am wondering which would best to get? Would it be best just to get another 6800GS and wait for the first revision of DX10 which is my current plan. Would a 7900GS OC'd preform better than SLI 6800GS OC'd?
What about ATI's side? I don't really want to spend that much more because I will upgrade CPU soon too. How does the X1950Pro stack up compared to SLI 6800GS.
Thanks alot.
you are best off just keeping your single 6800gs and waiting for ATI to release it's R600 and for Nvidia to release it's refresh. A 7900gs will outperform dual 6800gs's but you are best off just keeping your money til' the dx10 cards really start to come. same thing with the ATI cards, don't bother "upgrading" just wait to do a major graphics card overhaul instead :) just my 2 cents
The thing is, is that I am not one to go for super teh leet haxor top but rather the mid range :) Mid range Rev 2 was my plan and I really only need something that'll last till then.
EDIT: What I want is not to spend the money now but to be able to play games which are going to come out soon at nice graphics.
get a 7900gs or x1950pro, the x1950pro does perform better than the 7900gs which might be something to consider. Anyways you are going to need Vista and direct x 10 games to enjoy direct x 10 both of which aren't out yet :) so just get a half decent card now and then upgrade once you get vista (which is going to cost an arm and a leg).
That's why I am going to wait till later to get a DX10 card so I won't have to spend an arm and a leg. My dad is going to get me Vista so that'll be fine. Saphires fine right?
How much difference is there between the two cards? The 7900GS and X19050Pro?
EDIT: Worth the extra $13?
If you OC the shit out of your GS (mines sittin at 620/1600), its faster than a 7900GT easily. The X1950pros cost too much right now at $250
Check newegg, get the EVGA model for 185 with a $20 rebate, nice card :)
Wait your saying you can OC your single 6800gs and its faster than a 7900gt? Bahaha!
Compared in NZ they arn't that much off. I don't live in US so soemtimes it really makes asking people price/preformance questions :p So would it be smart if the 7900GS was $200 and the Pro $215 and to buy the Pro?
EDIT: Are you OC'ing a 7900GS or a 6800GS? :p :D
Would it be even possible to OC a 6800GS that far? Heat isn't a factor. Could the hardware handle that? :D
Best buy has the 7900GS on sale for $150.. pretty good deal, I picked one up a couple of days ago.
No problem. Anyone have the X1950Pro? Just i know what the 7900GS is like personally but want to know what the other is like.
