Since the cooling on my 6800GS makes so much noise I thought I would disconnect the fan, take off the cover and hold the fan above the HS and blow down (or up really
) on it with an 80mm (Vantec Stealth). Since the only thing I thought of to hold it in place was string connected to the four corners and to a different part of the case
My question is, will it work? Would the stock cooling work more effieciently?
