6800GS 3dmark scores
I got my evga 6800GS agp video card and poped it into my machine and everything is great with it, it plays my games really well, i could unlock the vertex unit but not the extra quad of shaders.
i just got threw running 3dmark05.. and it only got a score of 4370. It seems to me like the score should be higher. I think i remember reading the scores being somewhere close to at least 5k for the scores..
i had just installed the latest drivers i could use.. the forceware 83.40 drivers.. could there be an issue there? is there a much better set of drivers for my card? Am i doing something wrong. Or is it that i just need to overclock the card to get the performance that i want?
any information would be very helpfull
Thanks
What's your AGP apeture set to in the BIOS? 64MB won't cut it for 3DMark05; you'll need it set to 128 or 256.
hey look at that, i have the same processor you got. My aperature is set for 256 i believe. i used to have a 6600gt before an accident with it and i got 3120 with that card.. thats why it seems a little strange to me
I'm not entirely up on nVidia cards but I think 3100 is low for the 6600GT as well... don't know what the problem could be though. I ask about AGP apeture because my X850XT PE got 4700 in 3DMark before I set the apeture up to 256, bumping the score up to 6100...
AGP 6800GS is not as fast as regular PCIE version. It is possible to unlock and oc it tho to get 5000+ with AGP version.
Is there a best set of drivers i can use? or even a modified set of drivers that will boost my performance any?
True, but only because the memory is underclocked. He shouldn't be getting ~4000, though, that's just silly. There isn't anything to unlock either (they didn't lock its pipes for just being AGP). The AGP version is plenty capable of getting past 5000 of the box, especially if you have a decent sized AGP aperture.
Maybe you could post all of your specs? Drivers won't fix this, I don't think. Something's obviously not working right...
here are the specs for my computer
p43.0 prescott with ht
asrock P4S61
768 ddr400 ram 1512 and 2 126's
loaded up in an Antec case with a aluminum 120mm fan and a brand new 500w psu
The card has never gotten over 63"C and thats when i overclocked it to 406/1100
i got 4887 on 3dmark when i did that.
oh yeah.. and the evga nvidia 6800gs 256 AGP
hope this helps some
Phranq said:
Not really.
Yeah, just read up on the ORB scores and I suppose you're right. 3100 is actually right for a 6600GT.
Well, I don't know what your problem is with your card, other than the fact that when I cruise through the ORB looking for 6800GS scores there are some pretty low-scoring intel setups. Actually some low-scoring A64 setups there as well. Blah. Maybe you ARE getting good performance from the GS, all things considered. You've got more than enough RAM for 05, and I'll tackle anyone who says your CPU is a bottleneck. :mad:
You'd have to excuse me. My nVidia card in the other room is a Geforce 4 MX 440. Gets 350 points in 3dMark05. :p So I'm out of the loop on the newer cards. As long as it plays your games fine, I don't think you should really worry about 3DMark anyway.
What is this AGP apeture? Does changing this setting help performance? Any dangers in raising it? Thanks
The AGP Aperture Size, or AAS allows your system memory to be shared with your video card to allow it more memory for textures and such.
Look at it kinda like an overflow for your video card...if all the memory on the video card is actually being used, it can set aside a special section of system memory to load and grab data it would normally store on the card itself.
Your score is about right where it should be.
My score bone stock on the GS was around 4200, and just above 5100 with the shader and quad unlocked. Overclocking has pushed me to 5969, my goal is to break 6K. in 05
Your scores sound just about right for a 350MHz core and a 1000MHz RAM clock with the extra shader.... maybe a little lower because you are running 768 RAM (which means no dual channel).
I just bought the EVGA 6800GS CO 256mb AGP 400/1100 out of box and will have it on Tuesday. I also got the Arctic Cooler Silencer 5 rev 3. I will be using Ceramique. I will post my 3D Mark 2005 scores on Wednesday or Thursday. I believe the CO version means my pipes and vs are already unlocked to 16/6? I could be wrong. If they are not I will attempt to do that right away. I will then OC and see how high I can get this card to go. I just switched from a very disappointing Sapphire x1600 Pro 256mb AGP. So, I am highly anticipating this cards arrival.
[Muad|Dib]
the "CO" means copper heatsink
im also wondering some 6800GS scores, ontop of that, overclocked scores if any :D
my brother has the evga gs clocked at 400/1100, paired with a socket A xp3200 and a gig of value ram. I unlocked the extra pipes on it right away, so I dont know the stock scores, but with pipes unlocked it gets right around 5500. I'll go switch it back to stock in a bit and see what it gets.
I have the XFX 6800 GS PCI-E version with a 2.5 GHz Opteron (Opteron 148 with OC). The score was easily 6300 and with some OC and tweaking, 6600 in 05. That is with 12 pipes. There are some items to consider:
1. Your system is using mixed RAM. 1 GB using two DIMMs is better than using a mix in four slots.
2. Memory CAS is a big item with the P4. CAS 2 really helps. What is yours like?
3. The stock clocks of the AGP NV40 cored GS are a good bit lower than the PCI-E versions. To wake up the card, you need to unlock the other quad.
4. The PCI-E version runs at 1.38 V on the 110 nm core while the AGP is using just 1.3V on the 130 nm core (like the GT). It will not clock as high since it has less voltage.
5. The CPU is not a real bottleneck if you exceed a minumum threshold. For example, I get the same score at 3.0 GHz as 2.5 Ghz. But, 2.0 GHz is slower than 2.2 since the clocks are a little below the threshold. Been a while since I was on a P4, but 3.6 was a nice spot to reach.
Every system is a little different. Just have to tweak a little. I would expect a 5K score for the AGP GS.
LOL, sure it is ;)
My S478 3.0E @ 3.42 does pretty good with a 7800GT (500/1.18) PCI-E, in 3dmark06 i pull off 3937, and over 7k in 3dmark05
To the OP, does your mobo support PAT? and is it enabled? you can check this by looking in for cpu-z and in memory tab and seeing if performance mode is enabled. Your score would probably get where you want if you o/c. Although it makes no sense your basing your system worth with a benchmark even when you say it plays all your games just fine, getting a faster score might only relate to getting 2-8fps in any given game!
With the pipes locked back up it got 4800, the clocks were still 400/1100 though, I don't know what yours are, but a combination of them being lower and ^heavy's comments^ would probably make the difference.
