Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I you refer to the new 6800 GT Review at Guru3d linked from the [H] news page, using a temperature probe they found the GT under load read out 49C and the X800Pro read out as 66C. Keep in mind that this was measured using stock cooling and measuring on the heatsink backplate and not from the drivers. Basically his goal was to show the potential amount of heat that would be dumped into the case. Unless I missed his comment, I don't think he mentioned noise levels, but he seemed impressed with the reference nVidia cooler.
i wouldn't doubt that 6800gt is cooler, NV has some nice stock HSFs, like the bfg fx5900, but after looking at the pics of the testing method,, i'd have to say the results are borked, that back plate doesn't even touch the gpu and it is metal vs pcb measurement of the x8--pro
Yeah definitely hard to say since everything isn't identical, but seems like had seen elsewhere that the 6800 GT ran far cooler than the FX 5950. From everything I have seen the x800Pro's are on par with the 5950's as far a temps, so the numbers seem believable to me. Realistically the x800Pro is a speed bumped 9800xt with more pipes so I would expect it to run hotter. Seems like it was also the case with the 9800XT that a 3rd party cooling solution definitely beat the stock cooler. That being said, I still would say you proc or P/S (if it doesn't have proper air flow) will be the largest heat source in the case for the time being. Unless you are running outside the manufacturers spec I wouldn't be too concerned.
