6800 water cooling
lt.murda
Does the 6800 have the holes in the same places?Because I want to water cool it,but I'm not sure if the same block I'm using on my 5900xt will fit.Like is the core and the holes the same size?
Looks like it will fit fine. The only cards I had problems with were the BFG's. They seem to have smaller holes around the GPU for some reason.
My EVGA fit fine with a DD Maze 4. I think yours will be cool.
my 6800GT
