6800 Ultra problems. Low bench scores
bstout1
I have an Athlon 64 3400+ with 1 GB of Corsair 3200LLPRO ram and an EVGA 6800 Ultra at 400/1100. Nothing is overclocked. I was trying to check my video card speed and got the following:
Resolution: 1024×768
Demo: HardwareOC - d3c171
Detail: Maximum quality
Antialising mode: From System
Filtering mode: From System
Hardware DirectX level: DirectX 9
Heapsize: 512 MB
Score = 72.4 FPS
From what I have been reading, this seems MUCH less than I would expect. Please let me know if this seems about right or not. If not, maybe a hint about where to get started looking for problems.
Thanks.
Pyogenes05
Sorry, my bad. I am using the HardOCP benchmark for Half life 2 with the map listed in my results list.
Thanks.
Ok, I spent the last hour redoing everything. I used 3dnews-canal demo and the following settings:
6800 Ultra @ stock (400/1100):
1. 1024x768 with all High settings and Bilinear 0xAA 0xAF + sound = 117.80 fps
2. 1024x768 with max everything (6xAA, 16xAF) + sound = 90.75
6800 Ultra overclocked to 430/1200:
1. 1024x768 with all High settings and Bilinear 0xAA 0xAF + sound = 118.0
2. 1024x768 with max everything (6xAA, 16xAF) + sound = 93.99
Maybe that will clarify things a bit. I am quite a bit happier with these results.
Thanks for any input you might give.
Bill
Those seem about right.
Try 3DMark05 if you want another test, if there's anything wrong with the video card it will show.
man with a 6800ultra you should be playing with 1600x1200 or 1280x1024...ur resoultion is way too low...test your scrores then...
I will raise my resolution and see what happens. Downloading 3dmark2005 now.
Thanks.
Thanks.
I would also download RivaTuner and make sure that your totally unlocked. I also agree that a higher resolution will work much better, and don't forget the drivers. I also like 3DMark 03. I have had my share of 6800 Ultra problems, but once you get them sorted out you will be quite happy.
reran Half Life 2 bench at 1600x1200,4xAA, 8xAF, Reflect world and everything set to high with sound on: got 51.35
3dMark05 with standard "free" settings at 1024x768, got 5719.
I have RivaTuner installed and overclocked from 400@1100 to 430@1190 but not sure what you mean by fully unlocked.
I still have to overclock my CPU.
Thanks for the input.
Bill
The average score for a 6800 Ultra is 5,578.
That average includes overclocked Ultras and stock Ultras.
You can see the list here in post 2,352.
The last pic has the average scores for the video cards.
EDIT:
Wow!
I guess you know where it is.
You posted your score there 10 minutes ago.
Awesome, thanks.
