6800 Ultra ??flicker??
MYPEARL
Just got the card and my screen is flickering. as in it turns the screen black and then 2 seconds it comes back on. any help would be great. btw i just installed the 61.77 drivers.
Abit IC7-MAX3, Thermalright SP-94, Western Digital 2-WD740GD, Coolermaster PAC-T01-E1SLVR, Sony MPF920, MSI MS-8408A2, eVGA 6800 Ultra, Crucial Balstix 2-512MB DDR PC3200, P4 3.2 800Mhz FSB, Turbo-Cool 510 Deluxe
I have a Dell 2001 FP monitor. the monitor stays on , the power indicators always say green. however the screen/display actually goes to a black screen. about to throw this 6800 ulta against the wall. I have to have enough power beint that i have a 510w. what happens if you dont have enought power to the gpu? could i be using the wrong power tail from the supply?
Try booting up in Safe Mode and see if you get video then.
If yes, then its a driver setting most likely, if not, I'd guess bad card.
booted into safe mode and YES it is still happening. instead of opening folders. it happens when i close a folder or a screen. also when you click on start. anyone else having these issues with there eVGA 6800 Ultra?
thanks
wanted to add that I attended a LAN party this weekend and playing games was fine. I only got a black screen for 2 seconds 1 time. Just thought of it. whan it flickers. sometimes it makes the words fuzzy. and it has to flicker some xx times agian till it goes back to normal. i have 2 rails dedicated from my power supply so i really doubt its the power supply.
