What do you all think:
I have a secondary PC that acts as my 'friend gamer' PC, the PC my friends use when they come over. However it's a bit long in the tooth for current gaming. It's specs are:
A64 (90nm) 3500
2x 512MB G.Skill DDR400 CAS2
1x Seagate 15k RPM 36GB SCSI
1x Seagate 7200.2 160GB SATA
GF 6800 Ultra Extreme
I have a machine that's been acting as a server that can be easily replaced with another machine for this function. Mostly a media machine but it would work better as a gamer machine with a video upgrade:
A64 X2 3600
2x 1GB G.Skill DDR2-800
HDDs are moot at this point
PCI-E 16x Slot
I have looked around a bit to see what I could put in there and not spend too much cash and all I can come up with as a decent card is a Radeon 2900PRO 512MB/512bit found here: http://www.newegg.com/product/product.asp?item=N82E16814102706
GPU Review has this to say between the two cards: http://www.gpureview.com/show_cards.php?card1=302&card2=536
What do you all think? Are there better deals/performance to be had out there? I would think not but the masses may know better.
A64 (90nm) 3500
A64 X2 3600
PCI-E 16x Slot
