6800 ultra dual dvi problems
kleptic
when I hook up 2 lcd's using dual dvi to my 6800 ultra one of the monitors will show some flashing lines across it when their is more than one window on that monitor and the lines will move from the edge of one window over a window behind it. like if I have 2 web browswers open over lapping each other or any other type of window. Also sometimes the monitor will flash off and on.
I don't have any of these problems if I hook up one of the lcd's with a vga to dvi adapter.
I've changed out cables and swapped the monitors on the connections on the card and no matter what its always happening on the monitor thats hooked up to the left dvi jack on the back of the card if your looking at the comp from the back.
but all this goes away if i use the dvi/vga adapter. I tried different driver versions also
anybody know if this is a known issue or anything about this problem?
thanks
kleptic
