krazykrook
- Jan 8, 2005
My setup has been working fine for the past 4 days, but yesterday morning i turn on the computer to play a little css and right when the map is all loaded up and I've entered the server for a sec, the screen goes to a diagonal pattern of rectangles or something with a brownish pixled background, in which will remain there unless i reset. I have to reset everytime this happens. This also happens when UT2004 is about to go to the menu too. I've turned my cpu settings back to default and tried it, didnt work. Turned fast write off, didnt work. Ive tried two drivers so far, the 66.93 (this is the one which was working for a couple of days) and the 71.40 which also didnt solve my problem. Sometimes I have gotten into counterstrike source walked around for like a second, but then it just goes to that same pattern. that i described.
My specs
My specs
abit nf7-s v2
amd barton 2500
2x512mb corsair xms 3200 6-3-3-2
eVGA 6800 ultra
antec true 380w
Lite On LTR-52327S
NEC ND-3500A
120g SATA wd
160g SATA seagate
os: Windows XP SP1
any suggestions would be helpful.
Thanks
My specs
My specs
abit nf7-s v2
amd barton 2500
eVGA 6800 ultra
antec true 380w
Lite On LTR-52327S
NEC ND-3500A
120g SATA wd
160g SATA seagate
os: Windows XP SP1
Thanks
