6800 problems
Railroad
Hi,
I recently moved my gear into a new case, but there are some problems with the display. When I plug the DVI cable into the graphics card, the monitor wouldn't show a thing. However, when I use a VGA cable with an DVI adapter, there is a signal for the monitor. There is a little flickering though, barely noticable but it's really annoying me.
To isolate the problem to see if it was my monitor or graphics card, I replaced it with my old TI4200. When I plug the DVI cable, everything works.
Hence, I'm suspecting that it's my graphics card. However, the VGA cable with DVI adapter works on both DVI connectors on my 6800.
I'm wondering if anyone have any advice on this. And if it comes to this, how's the RMA process for XFX?
My power supply is an Antec Neopower 480.
Thanks in advance.
hook up both cables - go to your display properties, change the output to your DVI - than unplug your VGA - see if that works.
