This is a strange problem i'm having with 3 different 6800nu's (2 bfg's, and 1 pny) on both an Abit KV8-Pro and an Asus K8N-E Deluxe.
Whenever i overclock the FSB of the CPU past 220ish, i start get texture flashing in games, regardless of whether or not the GPU is overclocked and AGP/PCI locks are enabled.
Furthermore, it happens even when I have it set up so that the DDR3200 stays at 200mhz (400 effective); meaning that the only thing going up is in fact the fsb.
It happens regardless of gpu and mobo chipset driver version.
I've also played around with agp, vcore, and vdimm voltages. I cannot seem to find a solution.
Does anyone have any idea what might be causing this or a possible work around?
