Heywood Jablome said:yeah the x800xt and well the x series arent good with the open gl games
i concurIsaacav2 said:To be honest, I wasn't "blown away" like I was expecting with my rig in my sig. Sure it has great graphics and what not, but I'm kinda sappin that I got a GT. I just dont like having to overclock to get the rock steady 1280x1024 4x 8x with everything maxed in HL2. Get the Ultra or X800. Coming from a GT owner.
aZn_plyR said:Xt vs Gt..no comparison...x800xt, unless ALL you play is DOOM 3 and other opengl games...the XT is better...if you were talking about the ultra vs xt..that's a different story
{NG}Fidel said:It depends on a number of things.
A. Your Price range.
- If you have a small budget then the 6800GT is your card.
B. GFX Bus
-If you are going PCIE get a 6800GT, unless you find the X800XT for cheaper or only a small amount more.
Overall I say both cards are great and either way you win.
Wicked. Definitely getting a 6800GT then.aZn_plyR said:in cs:s you won't notice a difference between a x800pro/xt/xtpe 6800ultra/gt/gt@ultra
its cpu limited...
in HL2..the x800xt/xtpe will be a bit faster than the 6800's
its cpu limited...
dnottis said:I don't know if this would interest you guys but we just posted a 6800 Ultra vs X800XT PE review - HL2, CSS were very close at 1600x1200 4/8.
http://www.3dxtreme.net/index.php?id=atix800xtpevsevga6800ultra1
Enjoy.
Thanks. These cards are close enough in CS:S, I'm going to go 6800GT and overclock it a bit to ultra, or as close to ultra as possible. Thanks again for the link, very helpful.dnottis said:I don't know if this would interest you guys but we just posted a 6800 Ultra vs X800XT PE review - HL2, CSS were very close at 1600x1200 4/8.
Enjoy.
NCIX.com has eVGA 6800GTs on for like $490 or $500 Canadian this week.Hate_Bot said:The only problem with the Ultra is that it's EXTREMELY expensive here in canada. It's hard to find one UNDER $700. I'll just get an XT, and OC it to over X850 XT-PE speeds/
Edit: Even finding in GT under $600 is hard, But I've found an X800XT ofr $585 which will do me fine/
Erm.. 3dmark03 doesn't even use SM3, nor do either cards look alot different at default settings.ImLazZzy said:X800 XT goers, I have no intention to start a war but based on my recent experience with X850 XT, 6800GT and 6600GT. I'd say you can tell the difference on a good monitor. Im not talking about comparing them in Doom3 or HL2 'cause those games are kinda card biased.
With ralatively card neutral games, GT renders a bit better images than XT.
Plus, did anybody mention SM 3.0? OK, let me put it this way, just run 3DMark 03 on both and watch Game 4 Mother Nature and you will see. Speed isn't everything not to mention you can easily OC a 6800GT close to the Ultra. Also, XT generates tremendous amount of heat and will jack up the temp in your case BIG time..."Watch out, boy! She's a maneater..."
