I recently got the Koolance EXOS (dont make any snide remarks I have no case room and it was my first shot at water) and am about to take advantage of the $300 compusa 6800 GT card. Anyways since I went to water mainly to eliminate noise I wanted to know if the Koolance VPU block will work with these cards (again.... most other blocks dont work well with Koolance) and if the system is powerful enough to handle both a P4 3.0 (default volt) and the GT.
These are the 2 GPU blocks on the egg
http://www.newegg.com/app/ViewProductDesc.asp?description=35-127-002&depa=0
http://www.newegg.com/app/ViewProductDesc.asp?description=35-127-001&depa=0
Im not exactly sure of the difference between the 2?
BTW my current card is a 9800 w/ a VGA Silencer on it
