Clealiness
- Mar 11, 2006
Does any know what the normal core temp is for a 6800 GT? Mine idles at 70-74 degrees celcius and can get up to 90+ when running demanding games. Is this normal?
90 Celsius? Ouch...you have a problem.Clealiness said:Does any know what the normal core temp is for a 6800 GT? Mine idles at 70-74 degrees celcius and can get up to 90+ when running demanding games. Is this normal?
Discostu2120 said:Honestly that seems only slightly above average to me on a 6800gt. My 6800gt ran just slightly cooler than that when it was new (70c/90c). I replaced the stock cooler with a vf700-cu and that dropped the temps to about 56c idle 70c load. When I sold it I put the stock cooler back on with some as 5 and the temps were over 5c lower than when the card was new.
Running it at those temps may cause it to die slightly sooner, but I wouldn't worry too much about it. As long as its not artifacting, just leave it be and be glad you have a bfg.
quadnad said:but thats just the issue: you have an almost 15C drop in your IDLE temps by replacing the stock solution. that means that something wasn't making proper contact. either way, I figure that by both clearing the thing of dust and reseating the HSF will get him far lower temps.
Clealiness said:Well, it's a new card. I've only had it for 3 weeks. I may replace the stock cooler with the NV5, but that brings up a whole different topic.
Sniper_Merc said:Just for referance I went back and checked the temps I recorded back in 2004 when I got my BFG Tech 6800GT OC. Now realize that BFG popped the stock heatsink off and replaced the stock thermal grease with Arctic Silver 5 netting on average a 6C temp drop. Also I had actually replaced the AS 5 with Shin Estu which got me a further 6C temp drop still using the stock cooling. Temp readings from below are with the Shin Estu on the core. Initial temp readings when I got it were around 84C load.
Stock
Idle Temps
Ambient Room: 76.5 F
Ambient Case: 89 F
Ambient Nvidia Sensor: 36 C
Core Nvidia Sensor: 53 C
Load Temps
Ambient Room 76.5 F
Ambient Case: 91 F
Ambient Nvidia Sensor: 51 C
Core Nvidia Sensor: 78 C
Your temps are not too far out of bounds from what I've seen posted with other 6800 GT's, hell, if I turned down my case fans I could push mine to 95 C pretty easily.
If it were me, I would spend $5 on some Arctic Silver 5 and replace the stock thermal grease and see how it goes. If your temps are still high, then think about aftermarket cooling. Zalman VF 700 AlCu is a good choice, and it's noticeably quieter than the stock hsf.
As for me, back when I got this card in 2004, I got it the second day they were available for sale, thus no aftermarket coolers were available till months later so I adapted a Zalman ZM80D-HP to fit on my card, pic![]()
GL with the new card, I know I've enjoyed and still enjoy it.
