6800 gt cooling
kidicarus74
i have an eVGA 6800 gt and i'm getting a danger den watercooling setup. i was wondering if a maze4 gpu water block would work with it... i saw the 6800 cooler but really don't feel like dropping $125 on that part alone when i'm trying to keep under $250 for the whole setup. also, if it does work, what would i do for the ram?
The problem with the Maze 4 is that it uses 3 mm screws, and the reference design for the 6800 GT has 2 mm holes. Need to pull the heatsink of your card and check the size of the holes (needs to be at least 2.6 mm for a M3 screw to fit).
