6800 and the 6800GT
SidewinderX
Well, I was jsut browsing some sites, and I noticed that the 6800 is ~$300...while the 6800GT (mainly the pny one) is around $400...
I was under the impression the performance ranking was 6800GT < 6800 < 6800u ... am Icompletley wrong there, or is there soemthier wired with the prices?
6800nu < 6800gt < 6800u is right
6800nu 12pipe 325/700 128mb ddr
6800gt 16pipe 350/1000 256mb gddr3
6800u 16pipe 400/1100 256mb gddr3
Actually its 6800< 6800GT< 6800U, the GT is basically a lower clocked Ultra so its considerd the best buy. And they prices are about right but you can get them cheaper atleast the 6800 and GT.
don't bother with the 6800 ..its got crippled pipes lines 128 megs less ram and uses DDR-1 instead of DDR-3 .. so go for the 6800 GT which is excatly the same as the ultra minus some clock speed and a extra DVI port.
The 6800 is the "low-end" card of the series. One big step higher on the Nvidia ladder is the 6800GT and on top is the Ultra.
Bear in mind that while "crippled" with 12 pipes the 6800 is still considerably more power than a 9800xt that is still selling for more money so if your on a budget the 6800 is not a bad choice
