6800 AGP with no Bios, need help.
djolddawg
Trying to resurrect an old 6800 buy using a PCI video card to run the monitor. Using NVflash I get "Mismatch in 256byte page mode programing". Not sure what this means, but think all NV40s use 256byte. The ID on the card is so worn and frayed it is not legible, the only thing clear is the green square area that says its' a 128MB AGP. The card layout looks exactly the same as an eVGA 128, but with cookie cutter cards who knows. The EEPROM is blank. Trying to research this is difficult as most of the links to the old stuff are busted. Hoping some Expert will remember something and help me out. Please.:confused:
Update: Had to turn it off due to power failure, now get, "ERROR: could not enable PROM Pins".
Double check make sure you have the right bios, I'm not sure but I don't think that the vanilla 6800 was a 256-bit interface, I think it was a 128, I could be wrong but it might explain that you have the wrong bios.
http://www.mvktech.net/
These guys have just about every bios I've ever seen, double check and make sure you have the right one.
Hopefully you don't have a fried card :(
