6800 3rd Party Clock viewer?
macrospect
Hello, I own a 6800 ultra and have the OCing set to auto. My question is there a program out there that I can view the current core and memory speeds (kind of the same thing like CPU-Z does)?
Thanks!
In the same window that you turned on auto overlcocking on you should see the speeds for your core and memory.
Most people use manual overclocking and then you can get much higher speeds.
Yeah, I knew that, I was just wondering how I could view the auto-overclock speed that I was getting.
