SuperToast92
- Mar 10, 2012
Hey guys, quick question if you don't mind:
After testing in Assassins Creed 3 for about 20 minutes, I peaked around 76C with the default fan curve. CPU-Z isn't showing any throttling...is it lying?
The reason I'm asking is because of the many times I've come across reading that the keplar gpu's throttle once you hit 70C. However, I saw no decrease in the clock in either GPU-Z or PrecisionX. I'd rather run it around this temperature range to avoid noisy fans, if I'm indeed not throttling.
