So I am prowling the web, still being hurt by the 40k Dell wants for 16 1TB drives, as I come across these guys: Petabytes on a budget: How to build cheap cloud storage
Basically they took commodity hardware and build a 4U server that holds 45 drives at a cost of less than 8k. Yes, it doesn't do most of what enterprise arrays do, BUT it doesn't have to if all you need is some storage. It's still limited to a "single controller" if you want to call the motherboard that but if you consider that you can buy a second 67 TB storage array for the price of a 2nd controller for an enterprise array the Backblaze starts to look pretty sweet.
If you don't need 67TB raw you can buy fewer drives and further decrease the cost of the setup.
Then there's Coraid's EtherDrive which is also an open hardware platform and actually does what enterprise arrays do at a fraction of the cost. As sweet as that VNXe looked, considering the options I may just buy a couple EtherDrives instead.
