67. Prepare memory size information for function call: INT 15h ax=E820h
Qveon
What does this mean and how do i fix it? that is what my postcode thing is reading. Thanks.
OHH!! i have the answer to this one i think. is your system running fine even when this post code is showing? if you are and the post code is showing 67 then you fine. i was scared a bit by this issue when i ran into it awhile ago. id boot into windows and it would run fine but show 6.7., which means nothing. on all abit boards(mayeb all boards) with post code boxes, post codes with a decimal point in them mean nothing.
