50Cal
- Aug 15, 2011
Okay, so maybe i was spoiled with with the glorious 2500k, but holy hell these idle temps are driving me crazy.
setup:
6600k 4.1Ghz@1.24V delidded with CL liquid ultra and an H100i V2 cooling it.
The pump is running at its highest settings and fans at about 900rpm
Under less than 10% load my idle temps are 40-45C (21C ambient)
After i first delid my idle temps where about mid-30's but they've been rising ever since with no change to voltage or fan curves. I delidded again no issues with the liquid ultra hardening or anything like that. Same temps of about 40-45C at idle.
One thing to note is that i never reapplied any sealant, so there is no gaps.
Is this right? Do these chips normally run this hot? I've been a bit out of the loop but just a bit of research and all i hear is that everyone is delidding intels latest CPUs because of the shitty tim they use.
my 2500k at a higher voltage would be in the 23-26C with just a h100.
setup:
