computerdude
- Jul 14, 2005
I am thinking of upgrading to x800pro and have a 6600gt. Is there going to be a big difference in performance with the x800pro or should I stay with my 6600gt?
RQLe said:x800Pro vs 6600GT
12 pipe vs 8 pipe, 256bit vs 128bit buswidth
I would say it very noticable in the higher resolution with AA and AF on base on the buswidth. Probably not too noticable without any AA and AF. Might be best if you do planning to upgrade to the XL for $20 bux more for 16p.
Thats true. If you are looking for more performance, then upgrade to the X800pro. But if you can wait a while for the price to come down or newer model to come out, then keep the 6600GT for the moment. Its a good card, and if you can afford to wait, do so. Othereise, go for the x800.GVX said:About the only thing that the 6600GT will beat an X800pro in will be Doom 3.
