2Fresh said:9800pro and all maxed at that res? Must not have great grafx then....
MrMitch said:to run that res you pretty much need a x800xt
Gillette said:Whenever I see "Completely playable framerate" I immediatley picture trolls posting that the human eye cannot see more than 30fps.
"Completely playable" and "not looking like complete shit" are two very different things to most gamers....
consumer9000 said:You'd need a 6800GT/Ultra or a high end X800. The reason is MEMORY BANDWIDTH!!! The 6600GT is quick up to 1280x1024 if you like eyecandy, but then it's 128MB 128bit memory setup will get hammered at anything higher.
ECM said:Uh, I said all effects maxed and 2xaa, but just to make you feel better it's consistently in the range of 25-35 fps (unless you go into huge raids).
Don't hate me because I'm getting good performance out of a 6800GT (I also have an X800XT if it makes your ATI !!!!!! side feel better).
Gillette said:That said, I would consider 25-35 FPS to be complete garbage. Games that run < 45FPS give me a massive headache.
perfektrtw said:I have a 6800GT and I play WoW at 1920x1200 with everything turned up. It is mostly fast enough, but a few spots in cities and such will slow it down to 17-20fps.
I am looking at replacing it with a X800XTPE or X850XTPE... or just wait it out for the new cards. Have not decided quite yet.
